timing belt cover
Old Jan 25, 2007 | 03:42 PM
ford7589's Avatar
ford7589
timing belt cover
98 ford ranger ive tride for houres to git the timing cover of to change therostate its wedged up aginst the bottom pully anyone have a solution
Old Jan 25, 2007 | 05:53 PM
RangerPilot's Avatar
RangerPilot
What engine? Can you describe a little more how it's wedged? Perhaps you have to remove the pulley (bottom should be crankshaft)?
Old Jan 25, 2007 | 07:26 PM
ford7589's Avatar
ford7589
2.5 engine i unhooked the clips and the center bolt on the cover but the bottom of the cover is stuck on the crankshaft pully ?
Old Jan 25, 2007 | 08:33 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
You have to remove the crankshaft pulley.. you'll need to remove the bolt that holds it on and using a puller, pull the pulley off of the crankshaft.
