99 350 starting problem
Jan 25, 2007 | 12:00 PM
My 99 7.3 dsl just won't start when cold. If it is plugged in it starts fine,if not it fires for a second then quits. good battery,it would cook the starter if I cranked it long enough. Any ideas where to start first?
Jan 25, 2007 | 12:39 PM
It depends. Define "cold".
Jan 25, 2007 | 12:41 PM
I am kinda having same problems someone told me that it might be the cellenoid
Jan 25, 2007 | 12:45 PM
maybe if it stops turning over,if it continues to turn the solenoid should be ok.
Jan 25, 2007 | 12:48 PM
"cold" as in not run for 8-10 hrs and a temp. of around 40 F.used to start just fine down to -20 F.
Jan 25, 2007 | 02:38 PM
I recently had the same situation on my 99' and found the GPR (glow plug relay) to be bad. FYI.
NAPA GPR-109
Ford OEM
Stancor-White Rogers 586-902
Interational 1831646C1
I was going to get the international part but decided to go with the Stancor-White Rogers relay/contact due to it's heavy duty construction etc...
Hope this helps.
Dukernc
1999 F-350 CC Lariat Dually LB 7.3L, 6 speed, 4.10, Linex bed liner, 4" Magnaflow SST turboback exhaust w/ 5" tip
1990 F-150 XLT Lariat 4X4 SB 5.0 EFI, 3.55LS, Modified AOD w/auxiliary cooler, cat back, all around farm truck
Jan 25, 2007 | 03:00 PM
Sure sounds like the GLO system is inop..
Jan 26, 2007 | 10:51 AM
Yes it was the GPR,jumped the two large posts with a heavy gage wire and fired right up at -20 celsius.
(the gpr is the shorter of the two)will now hunt one down and replace it.
Thanks to all !
Will leave the mini jumper in the glove box for next time this happens.
tdowling99
Jul 14, 2011 05:28 PM
vic1125
Dec 10, 2007 06:22 PM
99FORD EXPY.
18
Jan 24, 2006 01:56 PM
designbc
Sep 3, 2003 09:59 PM
scottf
Mar 31, 2001 12:10 AM
