I Have An 89 F150 With A 300 Straight 6 With A 5 Speed. I Am Currently Running 36 Iroks With 9 Inches Of Lift. My Question Is What Size Gears Should I Go With? Right Now I Am Running 3.08's. Any Help Will Be Greatly Appreciated. Thanks In Advance!
Depends on what your doing. Heavy wheelin you'd want 4.56 but if more a highway cruiser I'd go 4.10. You have overdrive which will help with the RPM, I had the exact same truck but 4 speed. 4.10 was all I wanted since she was screaming down the highway.
Thanks for the info guys! Think I'm going to go with 4.56 with a detroit in the rear and a Auburn in the front. I'll hit ya back and let you know how they perform. Thanks again!
i just figured this out with 3.08's and stock tires to 36"tire and 3.93 gear would be needed to corect speedo but like every one else said id go to a 4:56 to gear it down a lil more
