Fuel Pressure gauge
Old Jan 24, 2007 | 10:14 PM
John311t's Avatar
John311t
Fuel Pressure gauge
Well, with all the problems the stroker has been having with fuel delivery, I just bought a fuel pressure gauge for in the cab. I want to know when it starts to screw up because it still acting a bit funny. I can't tell if its in my head and im just afraid of it diein again. Where do i hook this gauge up to? Its an autometer sport comp2 0-100PSI with electric sender.
Old Jan 24, 2007 | 10:24 PM
phatdually1's Avatar
phatdually1
The gauge sender hooks up to the back of the fuel/water separator on the back side opposite of the drain valve. There is a threaded plug there, I believe it is a 1/8 27 THD. I may be wrong about that, someone else might chime in. That is one location, there may be another location.
Old Jan 25, 2007 | 12:56 AM
jtharvey's Avatar
jtharvey
The back of the fuel bowl is a good place. There's a plug in there now. But, you will need an adapter to make it fit. I can't remember now what the correct size is though. I just took my plug out and went to the hardware store to find the appropriate piece with the proper threads. The stock plug is round with an female allen to remove it.
Old Jan 25, 2007 | 02:05 AM
Fat Diesel's Avatar
Fat Diesel
Go spray it soon with some liquid wrench or something. I tried and ultimately gave up trying to remove that plug. Others have had success.
Old Jan 25, 2007 | 03:14 PM
John311t's Avatar
John311t
Im gonna go spray rust breaker on it. It been staturated with diesel after my cap cracked last week. Ill update on this when the gauge comes. Im hopin its here tommorrow, but if not it wont be till monday.
Old Jan 26, 2007 | 01:58 PM
John311t's Avatar
John311t
Quick question! I got it all ready to install the gauge(should be herewithin the next 2 hours) and i saw two holes, one at the top of the bowl and one at the bottom. Which one do i take out??
Old Jan 26, 2007 | 02:11 PM
jtharvey's Avatar
jtharvey
Either one really but, the one at the top, on the driver's side, is easier to get to, IMO. They will give the same reading though.
