Hey guys I have no idea what's wrong with the truck?! It runs fine and every thing but my CEL is on and the reader won't pull codes or act like it's even plugged in! I've tried Advance and Oriely's but neither of them could read it so I went to ford and they said to check the power plug fuse cause they run the power off of it.. I checked it out and the fuse is good so I'm stumped.
Assembly Line Diagnostic Link, the port under the dash. My 02 F250 doesn't have an under hood fuse box, so if you don't find one they are all under the dash.
The aldl port is kind of low mounted and could have trash stuck in it. The fuse is going to be the first thing to check, but there maybe something in the port shorting the power wire out.
