where do I find the PCM code for Jody?
Old Jan 24, 2007 | 12:55 PM
dmueller71's Avatar
dmueller71
Question where do I find the PCM code for Jody?
How do I get the pcm code on an 01?
Old Jan 24, 2007 | 01:03 PM
ponch37300's Avatar
ponch37300
It is on the pcm which is located inside the truck on the drivers side fire wall. It is a metal box in a black plastic holder. It is about 5" by 7" by 1" thick. If you stick your head by the accelerater pedal and look towards the drivers side of the truck you will see it on the fire wall. Some can read the numbers with a flashlight and a mirror. I choose to loosen the 1 bolt that holds the wire harness into the pcm from the engine side of the firewall and remove the three bolts that hold the pcm inside the truck and make sure i read the right number. It only took maybe 10 minutes to take it out for my first time and i knew i had the right number for Jody. If you take it out make sure the keys are not in the ignition. Good luck and if you have any questions call jody. He has great customer service and he might be able to email you a set of his directions that have all the steps i listed and pics.
Old Jan 24, 2007 | 01:04 PM
wlihntr's Avatar
wlihntr
open the drivers door, look towards the front of the truck in the door jam. it should be on a sticker. if not than you have to pull the PCM and get it off of that
Old Jan 24, 2007 | 03:49 PM
dmueller71's Avatar
dmueller71
Thanks for the help. I found it and "GOTTER DONE"
