New guy some old questions
Old 01-31-2007, 11:03 PM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
Jacksfirstdiesel is offline
I'll make this brief. I have an '87 6.9 IDI with 2 tanks. tried running B100 in the front tank, B20 in the rear for start-up and to switch to in case it was too thick.I needed to thin it down to about B65 to keep it moving. Is it a good idea to put a heat exchanger in the system for both fuel tanks? should it be placed in front of the fuel/water seperator or where? There are some available on ebay. thanks
Old 01-31-2007, 11:13 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Where in CA?
B100 does not usually require "thinning" unless the temp is fairly cold.
Old 02-01-2007, 08:25 AM
willbd's Avatar
willbd
willbd is offline
Are you running strait vegetable oil in the front tank?
Old 02-01-2007, 11:18 AM
Jacksfirstdiesel
No I am not running SVO. The B100 is pretty thick (like 30 wieight oil) It is also pretty cloudy. The supplier is working on improving his process and this might improve with his experience and time. So I should not have to make any modifications to fuel delivery to run Straight B100?
Old 02-01-2007, 11:36 AM
willbd's Avatar
willbd
willbd is offline
All of the Biodiesel I have seen is like 5 wt oil.
Old 02-01-2007, 12:03 PM
Phydeaux88's Avatar
Phydeaux88
I dont know what it is but it doesnt sound like BD to me
ZHMMY
02-03-2013 10:22 AM
RocketmanVT
04-05-2011 03:31 PM
RocketmanVT
03-23-2011 08:15 AM
boots6868
02-28-2010 01:49 PM
TexAcoon
06-14-2004 10:14 AM
Quick Reply: New guy some old questions
