High Boost in Cold Temp
Old Jan 24, 2007 | 11:02 AM
fpd7's Avatar
fpd7
Unhappy High Boost in Cold Temp
I have an 05 6.0L Supercab. Stock except a coolant filter. When the outside temps are cold, the boost guage stays up near 10 lbs. It will go up when climbing hills, and down when idling, or slowing. But just cruising on level ground, it used to be about 5 lbs or less, but now it is up near 10 lbs. Is this just from the cold ambient temps? or is there a problem starting to show up?
