Modular V10 (6.8l)
Synthetic ATF ?
Old Jan 24, 2007 | 12:02 AM
jutahh1's Avatar
jutahh1
Synthetic ATF ?
Ayn thoughts on running synthetic ATF in '99 F250 ?
Old Jan 24, 2007 | 12:08 AM
monsterbaby's Avatar
monsterbaby
Sure I like the stuff, I run it in my race trannies and it' keeps the temp lower by 10 degrees, so if it can withstand what I put that trans through it sure isn't going to hurt in your F250. I also run it in my F250, never had a gauge on it before switching but I also have never had a problem with the trans either with 110,000 miles on it so far. Mine is a 2000 instead of a 99 but that shouldn't make a difference.
Old Jan 24, 2007 | 01:07 AM
LEVEL10's Avatar
LEVEL10
that is all we use. and have found the muliti vehicle full syntec from QS to work very well even in the 5r110w units and proved it with captchas's old truck. shifting is way improved, smoother. with less heat as per the pan temp guage we used testing it.
Old Jan 24, 2007 | 07:06 AM
Big Orn's Avatar
Big Orn
My manual says use nothing but.
'99 F350
