Flashing sensor light
Old Jan 23, 2007 | 11:52 PM
imrjeffrey's Avatar
imrjeffrey
Dear Gang,
Thank you for your replies on my first post. I have an 1997 E350 V10 4x4--it weighs about 9000 pounds. The guy at the transmission shop says that I need to keep the overdrive off unless I'm on really level terrain as this is what causes transmissions to fail prematurely. This doesn't make sense to me as I know a lot of people with the same vehicle as I have and they don't have this problem and I know that they don't ever turn their overdrive off unless they are towing. Did leaving the overdrive on cause my transmission to fail prematurely? I was also told that the torque converter locks up in 3rd gear, so wouldn't this also cause excessive heat or slippage? Do I really need to keep the overdrive off all the time? My trouble code is P1728. Does this mean that I need a new transmission? I'm sorry that I don't know what the temperature was when the transmission overheated as I just put the temperature gauge on.
Do the external transmission filters work? Are they a good investment or not? I was checking one out on The Diesel Stop for about $175.00. It's supposed to have a bypass valve built into it so if the filter ever clogs it keeps working.
What would you recommend for an inexpensive Code Reader that I could purchase that would read all the Ford codes?
Thanks in advance,
Jeff
Old Jan 24, 2007 | 06:20 AM
LEVEL10's Avatar
LEVEL10
Originally Posted by imrjeffrey
Dear Gang,
Thanks in advance,
Jeff
HELLO JEFF,
YOU CAN GO TO OUR WEB SITE TO CHECK WHAT YOUR CODE MEANS. WE HAVE LISTED CODES AND THIER FIXES. IF YOU NEED FURTHER HELP, PLEASE CALL.
MIKE
LEVEL 10 TECH
Old Jan 24, 2007 | 09:09 AM
hydro_37's Avatar
hydro_37
I leave my 1999 F-250 V-10 4X4 in overdrive all the time. Only time I turn it off is when I plow snow, Tow or when the tranny kicks down when headed into a strong wind. Tranny has never heated up.
Old Jan 24, 2007 | 12:19 PM
Leader's Avatar
Leader
My truck is ALWAYS in OD towing or not. 369,000+ miles on the orignal trans.
Reminds me... I should get it serviced again.. been over 100,000 miles since the last change.
