dies in reverse
Old Jan 23, 2007 | 09:30 PM
Trickedout420's Avatar
Trickedout420
dies in reverse
i have a 91 f150 5.0 e4od 4x4, well whenever i put it in reverse the trucks rpms will drop down to 300 and bounce up to 750 3 or 4 time sand then it will die, any one no what causes this? it doesnt do it driving in any of the other gears
and what kind of tranny fluid should be used in the e4od?
Old Jan 24, 2007 | 11:59 AM
Trickedout420
anybody know?
Old Jan 24, 2007 | 12:22 PM
Bertha1's Avatar
Bertha1
Could be the IAC needs cleaning or replacing.
Old Jan 24, 2007 | 03:08 PM
bohiaa's Avatar
bohiaa
I had a Ranger that did this....
it had a bad fuel pump relay....
if you pull codes it should find it for ya...
Mine was kind of werid.... it would do it in reverse only... unless ya hit a prety good bump...
Drove me Freggggin crazy untill I found it
Good luck
Old Jan 27, 2007 | 06:28 PM
fastman113's Avatar
fastman113
my 95 psd also acts like that but it happens in drive also and sometimes it will kill the engine, otherwise the transmission works fine
Old Jan 27, 2007 | 11:13 PM
77 Bronco's Avatar
77 Bronco
I had the same problem with a F-150 truck....turned out to be the transmission fluid filter. Heard that the filter drops down. Once I had it changed the truck was back to normal.
Sam
