Sputtering engine
Old Jan 26, 2007 | 11:00 AM
seawulff's Avatar
seawulff
I called Pertronix and they said that most of the problems with their ignitors occur at high rpms or with insufficient voltage at low rpms especially with cars equipped with generators. He suggested I test the voltage at idle to make sure that I have at least 8 volts which is the minimum. I think I will test out/change the plugs and the wires or maybe even switch back to points and condenser for a test before sending the Pertronix back. It looks like my weekend is starting to get full. Thanks for the input.
Chris
Old Jan 26, 2007 | 12:12 PM
brucewolff's Avatar
brucewolff
Originally Posted by bobbytnm
Chris,
Years ago I would check my plug wires by runnignmy hands down each one with the engine running, you would know when you had a bad one. (I quit using that method with the advent of electronic ignition....ouch).
Another way is to check your running engine for arcing at night in your garage with the lights off. My son found a plug wire this way.
Old Jan 26, 2007 | 12:26 PM
Jag Red 54's Avatar
Jag Red 54
Brucewolf is right. Do the easiest/least expensive checks first:
1. Run the engine in the dark. If it's a spark problem you may see the flash when the miss occurs. If that doesn't work-
2. Put a timing light on each plug wire in turn to see when the light fails to light during the miss. That would mean the prob is ahead of the spark plug wire. Plug end, cap, rotor, distributer, pertronix unit. No help?
3. Replace the plug that bit you. Still doesn't help?
3. Try your single new wire idea on each plug in turn. Still no clue as to why it's missing?
4. Go to a shop and spend some money on the scope. By the way, what did you gap these plugs at? And your generator should not be putting out 8 volts. Around 7.2v is just right. Let us know your solution, Jag
Old Jan 26, 2007 | 12:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is this a 6v truck?
The 8v value is for a 12v system with a ballast resistor, I don't know if Pertronix uses a ballast? What I didn't like about the Pertronix I saw was that it uses the stock cam lobes to generate a signal. The stock cam doesn't have nice crisp corners like a modern HEI-type system (toothed wheel). I can't believe it will provide an accurate, repeatable signal. Add in some wobble and it looks like a crap-shoot to me.
Old Jan 26, 2007 | 04:59 PM
Jag Red 54's Avatar
Jag Red 54
The two Pertronix units that I have came with a new cover that fits over the old cams on the distributer shaft. Maybe different models don't have that piece??? Jag
Old Jan 26, 2007 | 05:39 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Oh yea, Has anyone ever seen the blue octopus sitting on top of their engine??
I inherited a much abused 1968 F-100 from my brother when I was 16. The poor ol 360ci would barely run. One night I fired it off and opened the hood. WOW, I could see every wire
Basically, use all your senses, eyes, ears, feel, etc. intermittant misses and ones that occur only on light load can be a real devil to track down.
Chris,
I think I would start by just swapping one thing at a time. Start with the the spark plug of the cylinder that "bit" you, if that doesn't work, move on to the plug wire of that same cylinder. No sense "shotgunning" a bunch of parts at it, you'll never know what the actuall problem was that way. Take a systematic approach. Start with the simple and cheap
I wish you well
Bobby
Old Jan 26, 2007 | 07:33 PM
seawulff's Avatar
seawulff
Thanks, the first dilemma is that I can't find anyplace to sell me a single plug wire they all come in sets. I will get a single plug and start from there. I will fill you all in in the future once I have a solution.
Old Jan 26, 2007 | 09:41 PM
DonMckay's Avatar
DonMckay
Can you still buy bulk plug wire and put your own ends on them?
Don
Old Jan 26, 2007 | 11:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Don
I'd bet if you rummage thru the garbage at Auto Zone or any repair shop, you'll find a long enough wire you could use for this purpose. Just test it to see that it's OK.
(and you think you're cheap, Bobby??? )
Old Jan 27, 2007 | 10:48 AM
seawulff's Avatar
seawulff
The bulk wire I saw listed came in enough bulk to open my own shop! I will do a little dumpster diving and see what I can find.
Old Jan 29, 2007 | 09:46 AM
Jag Red 54's Avatar
Jag Red 54
Speed shops sell bulk wire. In Sac the place to go is Tognotti's. If you don't have one of these around, maybe just buy the set of wires when you get to that stage of the investigation. Jag
Old Jan 29, 2007 | 10:53 AM
seawulff's Avatar
seawulff
Thanks, Sunday I just changed out the plugs for some Autolites. I haven't driven it much since then because it's been raining and it isn't really water tight at the moment if you catch my drift. I'll keep you up to date on my investigation as it progresses.
Chris
chris_e150
Mar 8, 2013 12:46 PM
ResJudicata
Apr 25, 2011 01:13 PM
user 2833083
1983 - 2012 Ranger & B-Series
Mar 17, 2006 07:39 PM
pappasplace
Apr 10, 2003 08:26 PM
gdolson
1997 - 2003 F150
Oct 22, 2002 08:25 PM
