Sudden Vibration at 50mph
I have a 2003 Ford F150 SuperCab 4.2L V6 2WD with 70K miles. A few weeks ago I was driving on the highway and all of a sudden the front end started to vibrate so bad I thought I had a front tire blowout. I pulled over and all of the tires were normal. The entire vibration lasted about 10 minutes. When I got back on the road the truck drove normally again. After several weeks the same thing happened again, this time I didn't pull over just continued to drive and again the vibration ceased after about 10 minutes. This happened only 2 times in the span of a couple of months. Yesterday my clutch pedal dropped and I found that the slave cylinder leaked all of the fluid on my driveway. I couldn't engage the clutch and had to have it towed to the shop. Could this all be related or am I looking at multiple problems. Thanks for your help.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
To answer Whitecougar's question, yes the steering wheel shuck just as bad as the front end.
