Still hard start after flash!
Old Jan 23, 2007 | 09:19 AM
Txfodiesel's Avatar
Txfodiesel
When it goes below freezing, my 03 still wants to buck and jerk for about 7 seconds or so. Not as bad as it was before the injector flash, but still does it. the flash took cause i hear them buzzing on shutdown. Could I have some injectors that are 2 far gone? 56,500 miles on motor. EGR unplugged. No tuner since new flash. Still a puff of smoke on startup also. Any ideas?
Old Jan 23, 2007 | 11:08 AM
Reidicus's Avatar
Reidicus
Try using some conditoner. I recommend diesel kleen at it worked for me after two tanks and all was well. A puff of smoke on startup is fine as all trucks will do this when it is below freezing.
Old Jan 23, 2007 | 11:35 AM
l-m tech's Avatar
l-m tech
you could also use Fords pm-22 or pm-23.one is a anti gel and the other is a cetain booster.i would have a power balance done on the engine when it is cold.this could help identify the injectors that are still trying to stick when cold.if the reflash help then you might have a inj. or 2 still giving you fits.it also would help your starting if you went ahead and pluged the block heater in.
Old Jan 23, 2007 | 11:41 AM
BowTieHatr's Avatar
BowTieHatr
what oil do you use tx? maybe a thinner oil will help as well.
Old Jan 23, 2007 | 01:37 PM
Txfodiesel's Avatar
Txfodiesel
Well, I do use diesel kleen (grey) and i run rottella 15-40. Im in ft. worth area so it doesnt get real cold, 17 1 night last week other than that maybe mid 20's for a month or 2. Wondering what i can do to convince the dealer to check the injectors? Try to get them to replace them possibly. LOL...
Old Jan 23, 2007 | 01:39 PM
BowTieHatr's Avatar
BowTieHatr
well, if they are good at what they do, they will know the steps to a proper repair. you will be out of your truck for a few days though. good luck.
Old Jan 23, 2007 | 01:44 PM
Txfodiesel's Avatar
Txfodiesel
Thanks bowtie, Ill see if i cant use some the FTE forum knowledge on them. Ill keep yall posted after I get it done.
