351 Smog Removal
Old Jan 22, 2007 | 10:14 PM
ewturtle's Avatar
ewturtle
351 Smog Removal
Im swapping in a newer motor into my 87 F-150 and was wondering if anyone has a write up on how to properly remove and plug the proper lines so the motor will run well. Ive fixed my tranny issues and am now going to start on the motors. The newer motor has a two barrel intake while my old motor has a 4 barrel intake. Im going to swap the intakes so I can still use my carb. Any advice would be great!
Old Jan 23, 2007 | 08:31 AM
Kemicalburns's Avatar
Kemicalburns
go to your local machine shop. they should have the proper plugs for the back of the heads. you throwing a cam, and some headers on this build?
Old Jan 23, 2007 | 07:12 PM
ewturtle's Avatar
ewturtle
No cam but have a set of Hedman Headers that I got used but I don't think they are going to work. They're for a 302 with a C-4 and I have a 351 with a C-6. I'm going to bolt them on and see if they're going to work or not.
Old Jan 31, 2007 | 09:56 PM
ewturtle's Avatar
ewturtle
I know someone's already done this...
Help?
