Sponsored by: Real Truck
SuperDuty Audio
Old Jan 22, 2007 | 08:37 PM
westernillsigHDSD's Avatar
westernillsigHDSD
SuperDuty Audio
Hello all, First of all let me say thanks for all your help. With this forums posts I found and bought my First SuperDuty an '05 Crew Cab Harley Davidson. My problem now is I have a garage full of audio equipment and nowhere to put it. Does anyone have a link to building a subwoofer box that will fit behind the seat? and an easy way to replace the wonderful!!!, stock speakers? Thanks
Eric
Old Jan 22, 2007 | 09:32 PM
i eat hybrids's Avatar
i eat hybrids
I dont know if your trying to build your own box or not or if you want to buy it from ebay, but I found completed ones online.
http://electronics.search.ebay.com/f...Z1QQsofocusZbs
redford's Avatar
redford
FTE Leadership Emeritus
Start with this:
http://cgi.ebay.com/MTX-THUNDERFORM-...QQcmdZViewItem
Old Jan 22, 2007 | 09:33 PM
jake00's Avatar
jake00
supercrewsound.com has them I believe. I built one for 2 12's, but I think your truck has the captians in back
Old Jan 23, 2007 | 12:30 AM
alstaregixxer's Avatar
alstaregixxer
I built one in mine for 2 10" JL Audio w2's. Mine also has the captain seats in the rear (lariat) It's a tight fit to get standard 10's in there. I can post pics up later if you want. The only mod I had to do was raise the rear seat mounts by 1" with solid steel bar stock and good bolts for safety.
Old Jan 23, 2007 | 01:12 AM
shoobear's Avatar
shoobear
hey do u know if the stock ford stereo has rca plugs on the back of it for a amp? I was thinking about hooking up my sub and amp to the stock stereo......
Old Jan 23, 2007 | 10:25 AM
westernillsigHDSD
Thanks for all the help guys, i don't really want to go the mtx route (expensive), i've been looking at supercrew's boxes and that is going to be the only option i think. The stock stereo doesn't have rca's behind it, as far as i know. Anyone know how to get the doors off? and in the back does the plastic around the rear speakers just come off. I have a bench in the back.
thanks
Old Jan 23, 2007 | 12:36 PM
i eat hybrids
westernillsigHDSD, what kind of stock radio do you have? The six cd changer or the singal cd changer? I have the stock 6cd changer (audiophile) hooked up to two 12' mtx 5500. If you have the audiophile 6cd then it will work you just have to buy the convertor at circuitcity for $60.00
Old Jan 23, 2007 | 12:53 PM
Lonewolftx's Avatar
Lonewolftx
Wink Try this . . .
Eric
s
This 10" kicker sub fits behind the seat. See gallery for all pics . . .
Old Jan 25, 2007 | 09:17 AM
shoobear's Avatar
shoobear
Hey what wire off the factory deck should i use to power up my amp? The factory dosnt have a power ant wire.
I found this link for wiring, here are the colors:
Radio 12v lt. green/purple
radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Old Jan 25, 2007 | 10:35 AM
i eat hybrids
Shoobear, what factory deck do you have? Are you trying to wire up an amp up to it?
Old Jan 25, 2007 | 06:06 PM
shoobear's Avatar
shoobear
Hey i have the factory in dash 6 stack cd player. And yes i am hooking up a amp and sub. My amp has the high gain leads so i dont need rca plugs.
But i have to hook up the power ant to the amp so it turns on with the radio.
Old Jan 25, 2007 | 06:51 PM
i eat hybrids
shoobear what kind of amp and subs do you have?
Old Jan 25, 2007 | 07:57 PM
savage2211's Avatar
savage2211
You can hook it to the pink one.That way it comes on when you turn the ig switch.
Old Jan 25, 2007 | 08:46 PM
shoobear's Avatar
shoobear
Hey i have a pheonix gold amp and a dual voice coil ADS 10" sub.
I thought the pink wire was the one,thanks....
