I currently own a 2001 Ford F350/7.3L diesel. I discovered a small oil leak coming from the oil pan.... (If u are standing in front, facing the truck, this would be on the left side of the pan.. about 2/3 up i assume this the high pressure line??? coming out.. I guess my question is, this a easy fix and can I do it myself?? if so what do I need??. I've checked the entire engine with a very bright halogen light no leaks on top..
That link i posted is a kit international has to fix it with out dropping the pan (IE removing the engine), but sometimes tightning the nut will stop the leak.
