aih ?
Old Jan 22, 2007 | 05:29 PM
luvemhot's Avatar
luvemhot
aih ?
was going to get my own AIH plug and drill and tape it myself for the boost, except i dont know the size and thread type to get. anyone know?
Old Jan 22, 2007 | 05:33 PM
sean23johnson's Avatar
sean23johnson
do you want to know the thread size of the AIH or the thread size of the boost fitting?
boost fitting is a 1/8'' NPT.
Old Jan 22, 2007 | 05:36 PM
luvemhot's Avatar
luvemhot
both need the AIH thread sixe first
thanks
Keith
Old Jan 22, 2007 | 05:43 PM
luvemhot's Avatar
luvemhot
boy i should have look at that before i posted it
that would be i need both but the thread size for the AIH first
thanks
Keith
Old Jan 22, 2007 | 05:46 PM
sean23johnson
thanks
Keith
i read somewhere that you can use a cummins 12v oil drain plug. try a napa or parts store. or blackclouddiesel.com sells the plug already tapped for a boost gauge.
Old Jan 22, 2007 | 05:54 PM
luvemhot's Avatar
luvemhot
I will call napa i looked at the pre made ones but i was being a cheap sob.
BTW i like your sig JOHN 3:16
Keith
Old Jan 22, 2007 | 08:53 PM
bigtorque's Avatar
bigtorque
i got mine from BCD shipped to me for 27.00 bucks.
but, you could just pull the stock AIH out and take it too hardware store and put a nut on it too see what size and then just get the correct bolt. but dont forget you will need a phenolic or rubber type flat washer
Old Jan 22, 2007 | 09:25 PM
luvemhot's Avatar
luvemhot
was thinking of that Big toque but i live an hour away form a hardware store but i could do it when i am taking a different car to town
Thanks
Keith
Old Jan 22, 2007 | 09:50 PM
clux's Avatar
clux
The plug you need is metric, 22mm.
You can get one at most parts stores for about $8.
Old Jan 22, 2007 | 10:33 PM
luvemhot's Avatar
luvemhot
thanks clux
do you know how long? the pic's look like about 3/4 of an inch
thanks
Keith
Old Jan 23, 2007 | 07:50 AM
clux's Avatar
clux
You're going to need 1" or 1 1/2" length.
Old Jan 23, 2007 | 08:01 AM
luvemhot's Avatar
luvemhot
thanks Clux
Old Jan 23, 2007 | 08:03 AM
luvemhot's Avatar
luvemhot
clux is there a thread type or al the 22mm plugs the same?
Thanks Keith
Old Jan 23, 2007 | 08:26 AM
aklim's Avatar
aklim
By the time you go thru all that, is it really worth it? 27 is not that bad when the base plug is $8 plus some change.
Old Jan 23, 2007 | 08:39 AM
luvemhot's Avatar
luvemhot
the cheapest i found it for was 49 bucks
yep at 27 i would not wast my time
where did you find it at that price
thanks
Keith
