spark, no fuel?
Old Jan 22, 2007 | 03:41 PM
cuztom79's Avatar
cuztom79
spark, no fuel?
1986 ranger 2.9 v-6, i am asking this for a friend. he says turns over, has spark, but no fuel getting to cylinders, fuel pump is working, and there is pressure at the filter, i dont know much about this truck and havent seen it, is it throttle body injected or direct injected into the cylinder? i told him its probably hte injector. any help would be appreciated.
Old Jan 22, 2007 | 05:19 PM
87 XLT's Avatar
87 XLT
It's multiport injected, one injector per cylinder.
Since the pumps are running the injectors "should" also be getting voltage.
Might be that the computer is'nt pulsing a ground to fire them.
Tell your buddy to take a couple minutes to pull the trouble codes & see if that gives him any clues on this.
Old Jan 22, 2007 | 05:50 PM
Rags's Avatar
Rags
There are 2 fuel pumps > 1 in the tank ( supply pump ) and 1 on the frame ( pressure pump ) even though you are getting pressure at the filter you should still put a pressure guage on the shradder valve on the fuel rail. It won't start if pressure is under 30lb's pressure.
Also crank the engine with the pressure guage on to make sure pumps are still running while cranking the engine
Old Jan 23, 2007 | 03:25 PM
cuztom79's Avatar
cuztom79
thanx guys i will tell him!
