help help
Old Jan 22, 2007 | 07:11 AM
johndeer68's Avatar
johndeer68
Cool help help
hello I have a f250 with the powerstroke in it.The truck quit running it was like someone shut it off it was real cold that day.I have replaced the fuel pump glow plug relay coil and the fuel pressure regulator .I found a fuse blown it was for the wastegate solenoid and ingector driver module relay coil . Can any one help me and tell were that relay might be so i can reolace it thanks JOHNDEER
Old Jan 22, 2007 | 07:41 AM
Kwikkordead's Avatar
Kwikkordead
What year is your truck?
Try unplugging the fuel heater wire on the backside of the fuel filter housing and replace that fuse. The heater coils are known to short out, but I don't know if that fuse is the right one. It's just a common occurance, so I'm mentioning it.
