Intermittent Starting Problem
Old Jan 22, 2007 | 12:38 AM
rpatrick's Avatar
rpatrick
I have an intermittent starting problem that is driving me crazy.
93 F150 2WD 5.0L Auto 210k
On a morning where there is a really heavy dew or when it was raining the night before and the cool night air caused a lot of condensation my truck won't start.
It turns over fine
It smells like it is getting fuel - raw gas smell at the tail pipe
It acts like something is zapping the spark - probably somethign associated with the high moisture or condensation.
Under the hood, even on the wettest morning, everything looks dry. I have checked the distributor and it is dry inside. Plug wires look dry, etc.
By noon, after the dew burns off, it starts and runs fine.
What can I do to trouble shoot this?
Old Jan 22, 2007 | 08:36 AM
lostin90s's Avatar
lostin90s
Smile
I bet new cap and wires would take care of it. I never had trouble with coil .
I bought a 93 F150 it "was" just tuned up. 2 weeks later and first rain it barely started and missed.. It had cheap non ford parts swaped out ran fine. The caps draw moisture and wire will short out. But thats what I think . good luck
Old Jan 22, 2007 | 09:54 AM
quicklook2's Avatar
quicklook2
i agree, probably wires and cap.
use dielectric grease when putting wires on.
good time to put a new set of motorcraft plugs in.
Old Jan 22, 2007 | 09:58 AM
bohiaa's Avatar
bohiaa
I had a chevy truck that did this drove us nuts b4 we figured it out.
any little rain shower and it would drown out. I would keep a bottle of rubbing alcohal in the cab for just the rain shower across town.
tuned it up and no more problems it looked like the dis cap was the one letting in water
Old Jan 22, 2007 | 10:57 AM
rpatrick's Avatar
rpatrick
Thanks for the help - I'll try the dist & wires. That's what my gut feel was, but since the dang things never looked the least bit wet I was wanting to make sure.
What's do you think about the Motorcraft parts vs aftermarket?
Not trying to start a holy war, but I don't want to throw money away - Ford is pretty proud of Motorcraft
Old Jan 22, 2007 | 03:02 PM
Bertha1's Avatar
Bertha1
IMO Motorcraft is better than some aftermarket parts. I guess it depends on your budget. If you can't go all the way (distributor, cap, rotor, coil, wires, plugs, etc) I'd stick with Motorcraft. If money is no object, I'd go with MSD.
