timing check
Old Jan 21, 2007 | 08:32 PM
dragford's Avatar
dragford
timing check
So when I check the timing on my 87 F150 5.0, I need to disconnect the TPS plug from the distributor? Which side os the timing mark on to check with the light? Thanks!
Old Jan 22, 2007 | 06:44 PM
dragford's Avatar
dragford
Anyone?
What do I have to do to check the timing? THe ACTROn book for my code checker says something about a spout or something...HELP!
Old Jan 22, 2007 | 06:51 PM
andym's Avatar
andym
I've never timed a 5.0, but point the light at the crank pulley and see what jumps out at you. The plug that you're talking about is the SPOUT - SPark OUTput. It's what disables the computer-controlled ignition timing. It's a small grey plug that you can find in the wiring harness coming out of the distributor. Once you see it, it will be obvious to you.
Old Jan 22, 2007 | 08:43 PM
briguy's Avatar
briguy
Just went thru this with my 91 f150....like andym said it is a single connector...mine also was grey in color next to the connector for the TFI module on the distributor...have to unplug it before setting base timing....
