Front Disk Brakes Conversion 46 Ford
Old Jul 28, 2001 | 10:07 PM
34PUId's Avatar
34PUId
What works the best to update my front end to disks?
Old Jul 30, 2001 | 10:39 PM
fatforty's Avatar
fatforty
Hi, welcome to the boards, I would personally upgrade the entire frontend and put a mustangII frontend in it that gives you rack and pinion steering (power if you want it) and disc brakes. John
Old Aug 15, 2001 | 12:28 PM
CougarJohn's Avatar
CougarJohn
I put a Magnum front disk brake conversion kit on my '34 Ford P/U, which has the same solid front axle as yours. Went on fine, works great. It uses readily-available late model GM calipers if you need to replace them down the road.
The only problem I had was with squeaks from the pads that came with the kits.
Old Aug 22, 2001 | 09:50 PM
gsnort's Avatar
gsnort
Jonkoe
Jun 9, 2016 01:21 PM
Lug Nut
Dec 20, 2015 06:57 PM
willy2359
1978 - 1996 Big Bronco
Oct 16, 2015 05:26 PM
sweet55
May 24, 2015 03:47 PM
robbyriot
Mar 27, 2015 12:56 PM
