Sponsored by: Real Truck
Towing capacity
Old Jan 21, 2007 | 07:08 PM
Jocaren's Avatar
Jocaren
Towing capacity
Does ford have the best numbers for towing, i keep seeing that the chev and dodge have heavier load capacities WTF
I want to see some facts here lol
i know that 250s have a 12500 capacity but it says 2500 chevs have 16100 and dodge has 13600???
Old Jan 21, 2007 | 07:32 PM
firesoutmatt's Avatar
firesoutmatt
http://www.fordvehicles.com/trucks/s...eatures/specs/
This should answer all your spec questions .
Old Jan 21, 2007 | 07:53 PM
phish555's Avatar
phish555
For an 06 F250 srw, trailer towing is 12500 lbs, and 5th wheel is 16K and some change. Those figures for the chev and dodge are probably 5th wheel.
Old Jan 21, 2007 | 07:59 PM
vatreefarmer's Avatar
vatreefarmer
over 19,000 for a 2wd 350 dually, that oughtta keep um up at night
Old Jan 21, 2007 | 08:03 PM
phish555's Avatar
phish555
Most I saw on that spec page that firesoutmatt posted was 15k towing, that was 2wd F350 DRW
Edit: 19200 5th wheel
Old Jan 21, 2007 | 08:12 PM
06F250XLTFX4's Avatar
06F250XLTFX4
Ford F-350 DRW Crew Cab
-15,000# conventional towing
-18,600# 5th wheel towing
-26,000# GCWR
Chevy Silverado 3500 DRW Crew Cab
-12,000# conventional towing
-16,000# 5th wheel towing
-23,500# GCWR
Dodge Ram 3500 DRW
-24,000# GCWR
I not able to find conventional / 5th wheel towing numbers on the Dodge website.
Clearly we can see why we all drive a Ford Super Duty.
Heck, my F-250 5th wheel tow rating is 200 pounds less than what the a 3500 is rated for. Now that gives me the 6.0 grin
Old Jan 22, 2007 | 07:23 AM
Jocaren's Avatar
Jocaren
This is exactly what i wanted, thank you guys again!
Old Jan 22, 2007 | 07:53 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to SD.
Old Jan 22, 2007 | 08:26 AM
edjunior's Avatar
edjunior
Y'all gotta keep in mind also that those are the MAX towing numbers for "properly equipped". You have to take into account the engine, rear-end gears, long bed, short bed, and number of doors. All that has an effect on the tow rating of the truck. For example, with my 2003, crew cab, 5.4L, short bed, the tow capacity is only 7200 lbs. When I up it from a 3.73 rear end to a 4.10, I'm up to 8700 lbs. I have a 4.30 I haven't put in yet, but the tow guides don't give numbers for that. The new 3V 5.4's up the tow rating right off the lot. Obviously the V-10's and diesels with the 4.10's and beyond will up the tow ratings.
Old Jan 22, 2007 | 08:29 AM
phish555's Avatar
phish555
Don't know about the Chevy and Dodge numbers, but the Ford numbers were taken from the Ford web site listed above that takes all that you mention into account, i.e. cab size, gears ect...
Old Jan 22, 2007 | 03:34 PM
06F250XLTFX4
The numbers listed above are based on a 1 Ton Dually Crew Cab Long Box. Ford will out pull any 1 Ton Truck on the market!
