17inch wheel problem
Old Jan 21, 2007 | 01:25 PM
fred botti's Avatar
fred botti
I have a 03 f250 crewcab with factory 16 inch steel wheels. I have purchased 17 inch aluminum wheels from a 06. The front wheels hit the ball joint. The wheel will fit with a 1/2 inch spacer. Will this create any concerns? Also the studs do not stick out as far so the center cap also does not look good. Any suggestions or feedback will be appreciated.
Old Jan 21, 2007 | 02:17 PM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome to Ford Truck Enthusiasts!
You will need to ask your question in the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and look over the choices. You can post in the forum for your year of truck or you might want to try this one: https://www.ford-trucks.com/forums/forum64/
Good luck and enjoy the site!
RockAuto
Vendor Specials, Discounts, Product Announcements & Group Buys
Feb 16, 2018 08:13 AM
mitch150
New Member Introductions
May 3, 2007 05:16 AM
Newsheriff706
Apr 7, 2007 10:27 PM
petes66gt
Feb 6, 2007 05:09 PM
