Hey guys well im haveing trouble with my truck. I filled it up with diesal in Michigan today and drove it fine and then when i went to shut it off it was fine. So i got and start it put it in reverse and it shut off. JUst liek if i would turn the key off. So could there be water in the fuel and my fuel filter is done. Need some help ASAP. AS im stranded at a guys house right now.
92 F-350
Have you checked for water at the bottom drain on the filter? Is your water in fuel wire connected to the bottom of the filter housing, if so is the light on on your dash.
Possible to get bad fuel. Are your electrical connection on the IP in good condition and tight. The front drivers is the fuel cut off soliniod, should have 12V when the key is on. If not may be a ingition switch problem, you could hot wire the IP to get er home.
