Transmissions Available
Old Jan 20, 2007 | 11:47 PM
afbrian13's Avatar
afbrian13
I have a 76 F-250 4x4, 360 4speed truck. I like the 4 speed as a work tranny, but i'm going to to mostly using ths truck now as a daily driver. I'm not worried about ultra heavy duty or anything like that, but i was wondering what auto tranny options there are. What auto transmissions were available in these trucks? Are there any overdrive trannys that bolt to a FE block factory?
Thanks alot for you help.
Brian
Old Jan 21, 2007 | 10:35 AM
scottie2hottie's Avatar
scottie2hottie
To my knowledge there aren't any OD trannies that bolt to FE motors. gear vendors(and others) make aftermarket overdrives but I'm not 100% about your application.
Old Jan 21, 2007 | 11:41 AM
77f2504by4's Avatar
77f2504by4
http://www.ford-aod.com/ they have everything you need to put an aod trans behind your 360 fe.
Old Jan 21, 2007 | 02:21 PM
lasthighboy's Avatar
lasthighboy
as far as i know, the c6 is the only automatic that came in your truck. and with the divorced transfer case, it should be fairly easy to swap one in. it is not an overdrive trans but they are pretty strong, even stock, which would be fine for what u r doing. just find a truck like yours with an auto and take what u need. i believe summit sells a bracket to mount on your trans and u can run your shifter through ur floor (like the hot rods do) and u wont even have to swap steering columns.
Old Jan 21, 2007 | 02:28 PM
77f2504by4's Avatar
77f2504by4
with the adaptors that ford-aod.com sells, you can put an aod 4 speed automatic behind an fe. but you are right only the c6 was ever put behind an fe.
Old Jan 21, 2007 | 02:29 PM
afbrian13's Avatar
afbrian13
Thanks for that aod website-it's a bit pricy for now but will be good eventually.
As far as the swap, application, etc.
I have a 70 f-100 body(original 2x4) I swapped onto a 76 f-250.
It took me from a very worn i6/auto/2wd/4wheel non-pwered drum/manual steering to a v8/4speed/4x4/front power discs.
I like having the stick sometimes, but i've owned auto full size trucks before (85 f-250) and I think i'll leave my stick shift for my 280z
Anyway - i already have the column, linkages, floor cover to do the swap. Time to start junkyardin
bpimm
EcoBoost (all engine sizes)
Sep 15, 2011 11:30 AM
Fornatic
19
Sep 16, 2010 03:05 PM
brians1979f100
Jan 2, 2010 09:36 AM
unseenthings
May 11, 2006 11:08 PM
DFB2004
Aug 24, 2002 12:26 PM
