Sponsored by: Real Truck
Heated seat install
Old Jan 20, 2007 | 11:11 PM
250HUV's Avatar
250HUV
Smile Heated seat install
Hey all,
I'm going to install the H3's from heated seat kit . com. Any ideas where a good switched 10a wire can be found to tap into? Thanks.
250HUV
Old Jan 21, 2007 | 05:49 AM
hookd's Avatar
hookd
wow you need heated seats that bad? anyway go directly from the fuse panel you don't wanna tap into something and start creating more issues
Old Jan 21, 2007 | 09:13 AM
250HUV's Avatar
250HUV
Hookd,
A lot of years firefighting has taken its toll on the back. I just need a little something extra on these cold mornings. I've seen the spares on the fuse panel but are these switched on with the ignition? My thought is that they are constant hot. The install looks to be somewhat simple except for the electrical hook up part. Any other help would be appreciated.
250HUV
Old Jan 21, 2007 | 09:36 AM
stewcon's Avatar
stewcon
Do you have the upfitter switches? There is two (#3 & #4) that are 10amp switches.
Old Jan 21, 2007 | 09:43 AM
250HUV's Avatar
250HUV
stewco,
I put the upfitter switch mod in however I'd like to keep the remaining 10a and the 2, 30a for lights and other stuff. The seats have switches and fuses already. I just need the switched wire for the hook up. Great idea though. BTW the other 10a uppfitter runs the high idle mod through the BCP wire.
250HUV
http://www.heatedseatkits.com
