PSD lope
Old Jan 20, 2007 | 10:15 PM
RLC2269's Avatar
RLC2269
PSD lope
any suggestions what will make a 97 psd lope. It lopes real bad when really cold and lopes still even when its warmed up.
Old Jan 20, 2007 | 11:11 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
How is the oil, is it up to appropriate level, and how many miles/age does the oil have on it??
Old Jan 20, 2007 | 11:20 PM
ForemanES's Avatar
ForemanES
IPR
burnt wiring
torque converter issues
injectors worn or bad
Old Jan 21, 2007 | 12:58 PM
RLC2269's Avatar
RLC2269
oil has only a few thousand miles on it and level is fine. What is the IPR? I smell burnt wiring even in when i smell in oil filler. Why would a bad torque converter make truck lope? as for the injectors i don't know. my thinking is if they were bad the truck would run bad even when accerlerating and this is not the case, the truck runs pretty tough when i get into it. they are original injectors with 207k on them. I will change the oil again this week, that way i can rule that out.
Old Jan 21, 2007 | 01:59 PM
andy's 96' 250's Avatar
andy's 96' 250
it is probably wiring inside the valve covers. check the harnesses they're probably toast
