Offroad & 4x4
Twinstick np205
Old Jan 20, 2007 | 09:43 PM
79-400-POWER's Avatar
79-400-POWER
Twinstick np205
how is this done and what are the advantages?
Old Jan 20, 2007 | 11:59 PM
fishmanndotcom's Avatar
fishmanndotcom
if you have to ask then you havent searched! google it!
-cutts-
Old Jan 21, 2007 | 03:37 PM
79-400-POWER
-cutts-
no I havent, I am too lazy.
Old Jan 21, 2007 | 04:43 PM
fishmanndotcom
i ALMOST feel sorry for you!
you wont make many friends or get much help here with that crappy attitude!
-cutts-
Old Jan 21, 2007 | 04:55 PM
god.boots's Avatar
god.boots
too lazy to search, but you start a thread?? google it or search the forum. many topics about this.
Old Jan 21, 2007 | 08:04 PM
79-400-POWER
Lighten up! I have searched and got some good info, But I want to hear from some of you guys that have and or done this and what yall think.
Old Jan 21, 2007 | 08:44 PM
surewhynot's Avatar
surewhynot
I did it in my Bronco. I like being able to play in rear wheel low range. Front wheel drive came in handy once when I broke my rear u joint out on a trail. I let the rear driveshaft just hang and eased back on to camp. Its not hard to do, I made my own shifter up using 2 stock shifters and some scrap I had laying around.
Old Jan 21, 2007 | 09:29 PM
79-400-POWER
See, this is the kind of answer i was looking for.
Old Jan 21, 2007 | 09:37 PM
Huntersbo's Avatar
Huntersbo
This is off topic but I found an aftermarket NP 205 with a lower low range.
Old Jan 21, 2007 | 09:40 PM
surewhynot's Avatar
surewhynot
Have you seen the article showing how to grind the rails?
Old Jan 21, 2007 | 09:45 PM
fishmanndotcom
then you should have said that from the get go, i see too many ppl screw up b/c they are too lazy and i dont take very well to laziness!
i use mine to walk around obstickles like trees and large rocks i cant climb over. set the front in lo range, rear in neutral, lock the rear line lock, 2nd gear, smash the gas and the front end will come around. literally turn on a dime!
its also very handy to have the ability to disable one end or the other if somethign comes up and you need to limp back on just one axle.
here is a GREAT comparison pic of what you have to grind http://medusa.ih8mud.com/NP205/205ShiftRail.JPG
and here is the site that explains the whole process http://medusa.ih8mud.com/NP205/Doubler.html
-cutts-
Old Jan 21, 2007 | 10:28 PM
75F350's Avatar
75F350
I like mine to seperate the front, and rear ends, to dig in for a big winch pull. Trying to power brake the rig, usually does not work so well. By sinking the rear end in 2wd, I can then select the front only, and down she goes. Before, I usually pulled myself right out of my own holes without burrying myself.
Having the ability to manuver around obstructions in the road is another great advantage, especially with a fullsize rig, on a trail that is meant for jeeps. (just as cutts mentioned).
For some real fun, stick a 203 (half a 203) in front of the 205!
The other reason would be cool points! Be the only guy on your block with more than two shifters in the cab.
Hey cutts, you were kinda hard on the guy, huh? Maybe he did not post the way you wanted him to, but, he did post, and that is kinda what this forum is about, yeah?
Old Jan 21, 2007 | 11:44 PM
fishmanndotcom
not hardly! has nothing to do with how i 'want' him to post, its the fact that with a small amount of googling, the answers are in front of him! he didnt say anything at first about opinions! in that case i would have repsonded differently! (pfft, prolly not actually, lol). it takes longer to start a post and wait for answers than it would were to just google something close and get some good answers!
but he's good to go now! waitin to see if he actually does it!
-cutts-
Old Jan 22, 2007 | 12:00 AM
75F350's Avatar
75F350
cutts:
see what you mean, was only trying to get a rise out of you. Hope the guy does the mod. It realy is a good one, and most guys are figuring out that shifters can be made, and not bought. Makes the mod affordable too.
Old Jan 22, 2007 | 06:51 AM
surewhynot's Avatar
surewhynot
Because I made my own shifters, the only expense I have into it is gear oil and rtv silicone for the cover.
