oiling
Old Jan 20, 2007 | 08:31 PM
zrtkicks's Avatar
zrtkicks
oiling
Hey everyone, I have an oiling problem in my 67 352 and need some advice, it was rebuilt a few years ago and hasn't run much since, the rest of the truck is undergoing restoration, but I start it up on occasion, I had some trouble getting it timed, the marks don't line up, so I time it by ear, and as long as its cold it has 40-50 lbs of oil presure, but as soon as it warms up it drops to zero, it has a new oil pump, and a quick stomp on the throttle produces a rattle. I am stumped, spun bearing? bad crank? maybe he didn't have the crank turned and put in stanard bearings? any Ideas fella's? it would be greatly app. thank you, Warren
Old Jan 21, 2007 | 07:21 AM
390fe's Avatar
390fe
You need to verify that you either have oil pressure, or that you don't. What I would do is to install a good mechanical oil pressure guage, remove the distributor and spin the oil pump drive shaft with an electric drill, counterclockwise. If you get oil pressure while the engine is cold, put the distributor back in, start the engine and watch your guage.
My old 390 has about 40-45 pounds of pressure when I fire it up cold, 30-35 pounds at 2500rpm hot, and about ten pounds hot at idle. These numbers sound low, but my 390 has been running for 37 years.
Let us know what you find out.
Old Jan 21, 2007 | 10:07 AM
zrtkicks's Avatar
zrtkicks
390 fe:
You are great and wise, I will try it, although I have an autometer mechinical gauge indash, and it has oil in the line, and I have some spatter on the fender wells with the valve covers off, but not alot, how much should there be?
Old Jan 21, 2007 | 11:20 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well I'll try to address some issues? Excissive bearing clearence...New but bad oil pump..Timing to far advanced.. and shocking the rod and main bearing causing predetenation? and you may have some crap in the oil pressure line to the Gage..
But with that said..Oil pressure on FE's is not uncommen too run low..But you should have at leat 10psi at idle when hot...and some run higher...I think mine run at about 15 to 18 on a hot day at an idle!! When you have the engine rebuilt did you get the Tolerence spec sheet from the rebuilder? thats always nice to know...
But bottom line sounds Like timing is off..for you to get the knock..I would bring #1 up to TDC.. and make sure the rotor is point at that plug wire..and if its a stock motor try just 6* on the timing...for starters.. and if it been detonating to long ? you could have wrist pim slap? I dont know I didnt build the motor..Just things I would check..and then go to you Oiling situation..
RJ
Old Jan 21, 2007 | 12:17 PM
390fe's Avatar
390fe
Originally Posted by zrtkicks
390 fe:
Let's not get carried away now... I'm just the first to reply! Like RapidRuss said, the oil line to the guage could be plugged, the guage could be off just a bit, or you could have standard FE oil pressure. Great cold, but could be better hot!
If you're getting oil spatter on the fenders from idling the engine with the valve covers off, then I would presume it's oiling correctly.
As far as the rattling when accelerating, it could be a variety of things, including detonation. Once you're positive the oiling system is working correctly, I would try to get the timing sorted out before making any big plans on driving this truck. If what you're hearing is detonation, you're timing is too far advanced.
Good luck and keep those posts coming.
