Torque conv. questions
Old Jan 23, 2007 | 10:33 AM
ruger761's Avatar
ruger761
Well good to hear that unhooking the batteries reset it for you. The fluid and filter will help out too. You might also check to see if you have a factory in-line filter that is up by the cooler for the trans. Its a round little black filter sometimes hidden by the grill of the truck. If you have one nows a good time to change it
Old Jan 23, 2007 | 10:56 AM
Cuda_jim's Avatar
Cuda_jim
PCM controls the tranny, no TCM. I've had to pull the fuse a couple time on another truck. Turned out to be a hanging shift solenoid. Glad it reset for you. Hopefully the fluid flush will solve you trouble.
