charging issues
Old Jan 20, 2007 | 02:06 PM
grndlzrd's Avatar
grndlzrd
Cool charging issues
hey guys my infamous 90 f250 is at it again. just as a refresh i have a 1990 f250 351w auto trans 4x4.
after i got it fixed as some of you know i had a lot of problems it ran good for a few days now i have a charging problems
when i start the truck the volt gage reads like 9 volts but after it runs for like 2-3 min then the gage will jump to 14 volts ive even tested the bat and alt they both check out good. ive replaced the ground from the starter up with a better cable replaced all bat cables new alt wiring harness. any help would be good by the way truck starts slow if i dont let it run for like 30 min or so. any help would be great.
Old Jan 20, 2007 | 06:40 PM
mhg's Avatar
mhg
sounds like the regulator is going out
