Gear Compatibility
Old Jan 20, 2007 | 09:51 AM
peterbilt379exhd's Avatar
peterbilt379exhd
Gear Compatibility
I've got a 1964 F250 with 4.56 rear end gears. I've found a set of 3.31 gears out of a somewhat newer Dodge 250 pickup which I've been considering swaping in. I've been told I need a different flange to make them fit my Ford housing. Are there any other compatibility issues which I need to be aware of?
Old Jan 20, 2007 | 06:33 PM
jwtimme's Avatar
jwtimme
probably not going to fit unless the rear ends are the same, like both dana 60's
Old Jan 20, 2007 | 06:59 PM
banjopicker66's Avatar
banjopicker66
Try asking this in the forum that handles differentials; you might get the information you need:
https://www.ford-trucks.com/forums/forum69/
Good luck!
Old Jan 20, 2007 | 07:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The diffy case for a Dana (Spicer) 60 from a 1964 F250 shows two:
3.54 thru 4.10
4.56 thru 4.80
However, you may have to modify your driveshaft by using the companion flange from the Dodge. The present flange you have is for 1330 size U-joints. What Dodge uses is?
Old Jan 20, 2007 | 08:05 PM
peterbilt379exhd
I know they are both Dana 60 rear ends and that I can swap the companion flange. I've heard about some issue with the case being different between 4.10 gears and lower ratios and those above 4.10?
