O2 Sensor
Old Jan 20, 2007 | 07:49 AM
Drew2010's Avatar
Drew2010
O2 Sensor
I was crawlin around under my 96 f150 351 when i found an oxygen sensor hanging back by my transfer case. are there supposed to be two O2 sensors in the exhaust.i have a fake duel that i plan to make a true dual. is this affecting my gas milage? The truck runs fine though.
Old Jan 20, 2007 | 09:17 AM
'88_F-150's Avatar
'88_F-150
yes 96 is OBDII and that means 2 O2 sensors and it could be affecting your gas mileage and should be throwing a check engine light
Old Jan 20, 2007 | 09:34 AM
MustangGT221's Avatar
MustangGT221
The 2nd o2 sensor is part of the additional diagnostic system that a 96 vehicle such as yours has. It is a sensor that will tell the computer if there is a cat converter problem.
It also makes it so you can't remove the cat w/o a dummy sensor...but cats should be used anyway.
