I've got a 1970 F-100 SWB 2x4, and like many others I contacted Ford for a run down on the VIN and the returned paperwork stated alot of cool info.
The one that really got my attention was that the stock wheels were 16x6 steelies. anybody have any shots of these old style wheels?
Ford parts book does not list a 16x6 wheel for your application. The only 16" wheel for your application is a 16x5.5 with 5 bolt holes. Most F100/150's from 1965 thru the 1980's came with 15" wheels.
I'll get into a bit more detail as the paper states.
"You asked the CRC to provide you with the original specifications and optional equipment for your vehicle at the time of manufactor. Your vehicle identification number F10BRG74419, decodes as follows:
F10 F-100, Styleside Pickup B 300 CID 1V 6-Cylinder Engine R Manufactored at the San Jose Assembly Plant G7719 Consecutive Unit Number
This vehicle was produced on 12/16/1969 with the following options:
- 115" Wheelbase -6.50x16 ~ 6 TT Tires - Wimbledon White - Chrome Western Mirror ~ swing lock - Black Heavy duty Vinyl Interior Trim - Exhaust System - Three Speed Manual Transmission - Front and Rear Shocks - 3.70:1 Non-Limited Slip Rear Axle Ratio"
I understand that, but that means it would require a set of 16" wheels. I've never seen a set of original 16" five lug wheels of this generation (maybe I have and didn't know it).
16.5" on the CS unless you had split rims, they were 16" with
up to a 7.50 tire.
Being it is a 100 truck they only came with 6" wide x 15 rims.
To go wider look into mid 70's to 80's chebby truck rims, they
are 8" wide. The Ford centers are 13 1/4" diameter as well the 8"
chebbies rims. With a cutoff wheel remove the centers, jig up and
weld your own custom backspaced wheels with your Ford centers
to retain your wheel covers.
It's not rocket science like custom rim shops want you to believe
plus a lot cheaper for just wrecking yard parts that they also use.
I justed looked through a lot of dealer literature and never saw them as an option only 15's were mentioned for the half tons. Just looked at the '70 salesmans brochure and under options there are no 16" rims.
As said above 6x15 but I have a few that are 5.5 x15
for F100's. On the 16" rims they were splits on 3/4 ton,
narrow like 5". I don't recall 5x16 after 67 on 3/4 ton,
they went to 16.5 rims.
Half ton had 8.15 x 15 tires which became G series in the 70's.
