1989 150 no start
Old Jan 19, 2007 | 07:45 PM
1989 Ford F-150's Avatar
1989 Ford F-150
Question 1989 150 no start
drove my truck 4 hours ago and now all im getting now is normal crank over no start and a smell of gas.... 1989 f-150 5.8w/3 speed some one help me plz.
Old Jan 20, 2007 | 05:44 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 20, 2007 | 06:46 AM
subford's Avatar
subford
More than likely the TFI module on the side of the distributor is bad.
You need to check to see if you are getting spark.
Old Jan 20, 2007 | 07:49 AM
zstangkrewson's Avatar
zstangkrewson
Thumbs up
i believe its the fuel pressure regulator, stop cranking on it if you smell gas in exhaust pipe cause your washing the cylinder walls with large amounts of fuel, go to autozone and get one for 55 bucks....it takes 20 minutes to change and it should fire right up, i had same problem with 4.9 liter.....good luck.
Old Jan 20, 2007 | 08:10 AM
subford's Avatar
subford
To check to see if the fuel pressure regulator is bad just pull off its vacuum hose. If there is gas in the hose or coming out of its nipple it is bad.
