master cylinder
Old Jan 19, 2007 | 06:53 PM
Magic's Avatar
Magic
master cylinder
What you you guys think of the orginal type 49-52 ford master cylinder. I have a new one installed. But since its a big truck. ( F-4) I was wondering if I should try to change it to a later dual master cylinder. Also have anyone of you ever done this,on a bigger truck. I feel that the cast iron mounting bracket might be a problem. Finding one that would fit in the same original
location.
Old Jan 19, 2007 | 08:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The single mc's on the lighter trucks are pretty darn reliable. If your whole brake system is in good shape, hard lines, soft lines, wheel cylinders etc I think they're OK for casual use. If I were using it as a daily driver, I'd for sure go dual.
That said, I'm going dual when I replace my front hard lines (soon).
