Nobody Know????
Old Jan 19, 2007 | 05:10 PM
REGULO's Avatar
REGULO
Cool Nobody Know????
Few days ago I did this question and NOBODY seems Know How can I do it!!!!
Please give me an answer!!
The explorer and the sport trac 2007 doesn't has the traditional two hooks in the front bumper,
Where can I buy two aftermarket hooks???
How can I put in ???
Where can I place it?
Thanks
Regulo
Old Jan 19, 2007 | 05:15 PM
quicklook2's Avatar
quicklook2
any off road 4 wheel drive shop should be able to set you up.
Old Jan 19, 2007 | 06:48 PM
MisterCMK's Avatar
MisterCMK
I bought a set of hooks from the local farm and fleet shop. I drilled a couple of holes in the frame and bolted em up,.
Old Jan 19, 2007 | 08:18 PM
Steina's Avatar
Steina
CO River Rat
FordPartsDirect doesn't list hooks for years after 2005; not sure how you'd mount hooks on an '07 Explorer without whacking holes in the bumper.
Steve
Old Jan 19, 2007 | 08:47 PM
REGULO's Avatar
REGULO
Lightbulb
Yes Steina!!!!! that's the point!!!!:
how you'd mount hooks on an '07 Explorer without whacking holes in the bumper.??
Old Jan 19, 2007 | 09:08 PM
Steina's Avatar
Steina
CO River Rat
Guess Ford didn't think that far ahead with the '06 and '07 models; it COULD be done given enough time and $$$, but it would probably ruin the smooth look of your '07's front end.
Steve
Old Jan 19, 2007 | 09:09 PM
88FordF-150's Avatar
88FordF-150
REGULO, lets cool er down a lil bit. If there are no factory holes to install them, then u WILL need to cut some holes, common sense, unless u can buy a bumper with holes pre built into the bumper. Now on the other hand u might be able to mount them under the bumper, im not to familier with that application. So go out, look under and investigate, find some good points to mount to, make sure they will be able to be accessable, drill, bolt in.
Old Jan 19, 2007 | 09:25 PM
MisterCMK's Avatar
MisterCMK
I was able to mount my tow hooks just behind the lower valence onto the frame so that when I have a strap hooked up its just below the valence and yet the hooks are hidden. You might be able to do the same.
