81 Hard/Won't Start when cold...thoughts?
Old Jan 19, 2007 | 12:19 PM
VirginiaWiFinder's Avatar
VirginiaWiFinder
Hey All..
I've got a 81 F150, 351M, factory reman carb bought and installed by P.O. New plugs, IGN module, super coil. Truck fires right up on first lick when it is above 50 degrees out...but here lately it doesn't like to fire up when its cold outside (+20 to +50 or so) Hasn't got below 20 yet. I can hit it with a quick spray of either it will fire off. But how annoying. Its almost like its flooding out maybe? Doesn't seem to matter if I hit the gas or not.
Choke is fully closed. Plenty of gas squirting in when I manually work the throttle.
Where should I start looking first? Thanks in advance.
Old Jan 19, 2007 | 01:17 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Sounds like a choke problem to me, but the choke is fully closed. Hmmm...
Iced up carb perhaps?
I do know that they do not put the antifreeze in the fuel for carbureted engines anymore. Perhaps the jets are freezing up???
I use rubbing alcohol to help with my cold weather fuel issues. Works like a champ. It will also help absorb water in the tank and make it combustible.
Just some thoughts...
Old Jan 19, 2007 | 01:36 PM
VirginiaWiFinder
So...just dump a few bottles in the tank?
Old Jan 19, 2007 | 01:53 PM
81-F-150-Explorer
I dump a 32 OZ bottle in a full 20 gallon tank.
I'm not going to say it will solve the problem, but it wont hurt either, and it make mine run a heck of a lot better in cold weather and helps prevent carb icing.
