tires
Old Jan 19, 2007 | 08:52 AM
scottddove's Avatar
scottddove
tires
Looking to buy some used 35x12.50x16 supper swampers from another member here and was wondering if they will fix on my 86f-350 without a body or suspension lift. I have stock wheels on it also right now I am guessing these wheels will not work with these tires. thanks for the advice/help.
Old Jan 19, 2007 | 11:48 AM
Sycostang67's Avatar
Sycostang67
They will fit on the back ok, but is your truck a 4wd? If yes, then they will probably fit with a little hammering or minor trimming of your fender corners. Make sure your wheels ar 16", and not 16.5"
Old Jan 19, 2007 | 12:04 PM
1970Custom's Avatar
1970Custom
He is right, they will fit but will need trimming as 33s barely clear on a stock truck.
Also remember that backspacing will become an issue and you'll probably rub at full lock one way or another or both.
