Axle Swap
Old Jan 18, 2007 | 10:09 PM
Henry Burnside's Avatar
Henry Burnside
Axle Swap
i HAVE A 97 F150 DRIVE TRAIN , Will the rear end bolt in I am able to weld hangers and change pinion angle. Going to make and install front susp. and brackets on front , would like the rear so all bolt patterns would be the same.My project truck is a 48 ford have clean no rust cabe with new bed kit and running boards.THe frame is solid and clean. Thanks
