No pressure in cooling system
Old Jan 18, 2007 | 06:21 PM
DaFueler's Avatar
DaFueler
Just did a waterpump chang in a F350. Don't see any leaks and coolant level hasn't dropped, but when I squeeze the upper hose it is soft and barely a hiss when removing the cap. Truck doesn't overheat, got it to 191F, temp went right back down when I quit running it hard. Is there a special way to fill it? Something need to be bleed?
Old Jan 18, 2007 | 09:14 PM
Ultramagdan's Avatar
Ultramagdan
The best way to bleed them is to elevate the front of the truck so that the air moves to the radiator and then out the cap instead of being stuck in the block.
