Door Lock Problem
Old Jan 18, 2007 | 12:09 PM
FARM69's Avatar
FARM69
Door Lock Problem
I've been having some problems with my door looks i.e. the key doesn't want to turn the lock anymore. I've oiled the locks from the outside and it seems a little better but not by much. Sometimes I have to stand there for a couple minutes and try to turn the key back in fourth until it will move. I guess this is not a big problem, but one of these times I'm gonna break the key off.
On my passenger side the lock will not turn at all. I'm assuming this is because its never used and has rusted up.
So my question is should I buy new locks or can I take them apart and clean them up?
Old Jan 18, 2007 | 12:11 PM
Ilikebigtrucks's Avatar
Ilikebigtrucks
My Driver's side is totaly frozen - since I bought it. For Better or worse the truck has keyless. I've been meaning to pull it appart but of course this requires taking to door panel off. Some day...
Old Jan 18, 2007 | 12:35 PM
jboard's Avatar
jboard
Our local locksmith had mine in stock I just took him the old one and my key and he matched the new lock to my key in about 15-20 min and it was only 13.00 bucks. If I was you I would look one up there really good in knowing what there doing. and suprised me how cheap it was.
--------jeremy
Old Jan 18, 2007 | 12:56 PM
MADVAN's Avatar
MADVAN
Your problem is likely to be the key is warn. The lock is fine. What i have found is the tip of the key wares down causing the key to go in the lock to far. Try a new key first. Most likely will fix your problem.
Bill
Old Jan 18, 2007 | 01:51 PM
Brians97F250Crew's Avatar
Brians97F250Crew
yup could very possibly be a worn key. If you have a second key that hasn't been used as much try that one and see if it works better.
Old Jan 18, 2007 | 02:49 PM
FARM69's Avatar
FARM69
I have tried both the spare and the reg key. The key I'm using now does look better than the old one. The old one (or spare) has the metal coating worn off of it.
They both have problems turning the lock...
Sounds like I should look into the lock smith thing?
Old Jan 18, 2007 | 03:44 PM
DaFueler's Avatar
DaFueler
Putting oil in a lock will gum the works up. Try cleaning it with the areosol de-icer. If you lube the locks it should be with a dry lubricant like graphite.
Old Jan 18, 2007 | 03:47 PM
FARM69's Avatar
FARM69
hmmm... its freezing cold out. Aka it has gotten worse lately. I bet my wd-40 is all gumed up and have frozen most of the time.
Old Jan 18, 2007 | 04:22 PM
Dirty_Pile's Avatar
Dirty_Pile
My driver door lock is like that. I can stand there and wiggle it and eventually it will turn. Doesn't seem to be frozen. New keys and old have the same trouble. I think the barrel is just worn and a locksmith is in my future.
Old Jan 18, 2007 | 04:26 PM
DaFueler's Avatar
DaFueler
The oil will gum the barrel and the pins in the barrel making for alot of wiggle before the pins fall into place.
Old Jan 18, 2007 | 06:58 PM
plowhand's Avatar
plowhand
Playing in the Dirt
FYI, either the front half or is it the back half of the key works your door locks (I can't remember which, but your dealer will know).
So with that in mind, if the locksmith does not work (it did not for me, the barrel itself was worn) you can take your key to your dealer, have them read your key code (by measuring your key) and find the common cut. Then they can order new door locks with keys and when they come in they can cut the ignition part into the new key. This way you will have two new door locks and the same ignition with new keys.
I also had them cut me a key with just the door lock on it and put it under the truck in case I lock my keys in. This way if someone does find this key under the truck, they can only unlock the doors, not drive my truck off.
