97 expedi engine cooling problem
Old Jan 17, 2007 | 10:32 PM
97umo2006's Avatar
97umo2006
this 97 expedi has a problem with coolant keep over flowing from recovery tank. i insalled new cap;changed thermostat;flushed and add new coolant. i am also noticing that there is no heat coming from heater vents. if driving vehicle or idling for a period of time - the temp guage shoots to hot all at once and oil light comes on,then engine start running terrible. stopping the engine to let cool down 3-4 minutes -when restarted it runs normal for a while. can anyone help me with this problem. thanks
Old Jan 17, 2007 | 10:38 PM
aagitch's Avatar
aagitch
Are you getting coolant in your oil? Blown head gasket maybe?
Old Jan 18, 2007 | 12:54 AM
97umo2006's Avatar
97umo2006
97 expedi engine coolant problem
no , there is no water in oil or steam from tail pipe. thanks for the response.
Old Jan 18, 2007 | 09:28 AM
97umo2006's Avatar
97umo2006
hello ; how can one be certain a water pump is needed ? vehicle runs normal for awhile even after warm -up period . then suddenly the temperature rises and coolant comes out degas tank and truck runs lousy . let it set for about 4 minutes and its back to normal . any suggestions ? thank you !!
Old Jan 18, 2007 | 09:49 AM
MisterCMK's Avatar
MisterCMK
Your water pump is probably shot. Start the truck and let it warm up. Now grab the upper radiator hose (it will be hot!) and see if you can feel coolant flowing or if its even hot.
Old Jan 18, 2007 | 11:18 AM
97umo2006's Avatar
97umo2006
thank you for the response - I tried holding the upper radiator hose pinched and folded together while engine was running at operating temperature,there was no pronounce or force of pressure felt. do it suppose to build up pressure while holding the hose together. I PROBABLY NEED A WATER PUMP. thanks for the reply -
Old Jan 18, 2007 | 03:43 PM
aagitch's Avatar
aagitch
Does sound like a water pump
