please help with troubleshooting
Old Jan 17, 2007 | 09:48 PM
muddman's Avatar
muddman
Question please help with troubleshooting
I have a 89 ford f-250 and the motor was blown when I got it so I put a 351 w in it that I had just had rebuilt. It ran great for about 2500 mi. no problems when I went out to start it one morning it just wouldn't fire, it spits a little like it might fire once in a while but other than that it just turns over. It has spark and it has fuel, I can't figure it out. it has a points dist. and a 4 bl. carb. any input would really be helpfull. thank you much
Old Jan 18, 2007 | 06:30 AM
ubereal2's Avatar
ubereal2
Sounds like you may have lost fuel pressure, or possibly a timing issue.
Old Jan 18, 2007 | 11:15 AM
WarWagon's Avatar
WarWagon
IF.....it has "good" spark and "ample" fuel......then check for proper valve and ignition timing. If that checks out totally, do a compression check. Keep an open mind.
Old Jan 18, 2007 | 06:25 PM
muddman's Avatar
muddman
not saying thats wrong by any means butwhat could make the timing get off if it was running well the night before and the next morn it won't start. Im not very familar with an electrical system. thank you for your input
Old Jan 18, 2007 | 07:19 PM
HemiEater's Avatar
HemiEater
sounds like fuel the way it spudders like it wants to start.....Check the wiring at the fuel pump relay, my plow truck had a bad connection at that plug.
Just a guess.........
