More power
Old Jan 17, 2007 | 09:38 PM
QuadRacer110's Avatar
QuadRacer110
Exclamation More power
Alright im sure all of you have heard this before.. I want more hp out of my 05 6.0. Right now i have the Edge chip, Banks full exhaust system and the K&N Cold Air Intake. Yet this is still not enough for me, i am just wondering what there is to do to get more power out of this beast. I am only getting 9 mpg now so mileage is no issue to me( 8" lift on 38's). I was thinking of getting new injectors?? But i do want to keep reliability in mind here,but im not afraid to drop 5k into it either. I just dont want to blow a head gasket or a motor!!
If anybody has suggestions please let me know
thanks
Old Jan 17, 2007 | 09:46 PM
6L PWR's Avatar
6L PWR
Note my signature.
Old Jan 18, 2007 | 02:09 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Then honestly, leave it alone....what you are running now is about all the stock head gaskets will support; perhaps a hotter tune would be safe, but any other hardware modifications will warrant new gaskets and head studs.
If you decide to go the head stud route, give us a call....we've got injectors in any sizes from 160mm (stock is 135) all the way up to around 350mm (and even bigger with hybrids) along with turbos, oil systems and other hardware needed.
Old Jan 18, 2007 | 02:28 PM
Lonewolftx's Avatar
Lonewolftx
Wink Try this . . .
You should invest in an SCT Xcal2 tuner and add an accufab performance intake elbow to maximize what you have now . . .
Old Jan 18, 2007 | 07:18 PM
jdadamsjr's Avatar
jdadamsjr
Yep -save your tranny and say bye-bye to the edge... b4 it puts you over da edge
Old Jan 18, 2007 | 07:23 PM
Reidicus's Avatar
Reidicus
If you are in the market for injectors, check out DSG Canada. They can bore out your stock injectors, and are great to deal with!!! Also, as long as your truck was made after may '05, the head gasket shouldn't be a major concern!
Old Jan 18, 2007 | 07:27 PM
zed326's Avatar
zed326
Hey 6l Power Does Removeing The Egr Give You More Power ???
Old Jan 18, 2007 | 08:10 PM
slowmans's Avatar
slowmans
i thought the new headgaskets didnt come out until around jan 06 engine build? sorry to hijack the thread,
Old Jan 18, 2007 | 08:21 PM
6L PWR's Avatar
6L PWR
Hard to say since I did this AND put in Stage II Injectors at the same time. Logic says yes since I took the big scoop out of the uppipe, but I can't say for sure.
Old Jan 20, 2007 | 08:34 AM
jwd1475's Avatar
jwd1475
[QUOTE=PSD 60L Fx4]Then honestly, leave it alone....what you are running now is about all the stock head gaskets will support; perhaps a hotter tune would be safe, but any other hardware modifications will warrant new gaskets and head studs.
Matt
How about water methanol injection with 25% methanol. Will the stock head gaskets support that along with a tuner and exhaust.
