Ignition switch replacement
Old Jan 17, 2007 | 08:25 PM
sundug's Avatar
sundug
I replaced the electrical end of the ignition switch in my 1970 350, and I`m trying to remove the lock and tumblers from the old one, I inserted a paper clip end thru the hole in the key face, I can see that I`m depressing the latch, but the tumblers won`t come out, any ideas? Thanks, Doug
Old Jan 17, 2007 | 09:56 PM
vinlin95's Avatar
vinlin95
ignition switch
had the same trouble. spray it down with crc electric cleaner. has gunk inside. lube it back up when you put it back together. hope this helps.
Old Jan 17, 2007 | 10:47 PM
Mil1ion's Avatar
Mil1ion
Turn it to ACC first..then insert paperclip ..push it in..then turn key counter-clockwise
Old Jan 18, 2007 | 05:08 AM
jowilker's Avatar
jowilker
It is possiable to do it correctly and it still won't come out without drilling it.
John
