dusted turbo wheel
Old Jan 17, 2007 | 06:13 PM
ForemanES's Avatar
ForemanES
dusted turbo wheel
This weekend I replaced the injectors on my truck and found the turbo wheel is missing some edges . Is this one (Click here) the same one? I havent been able to fully enjoy my new stage 1s in fear that 30+ psi will tear it up more. Oh and this truck had a drop in k&n in it for 50,000 miles. I will post some pics when I replace it.
Old Jan 17, 2007 | 06:22 PM
ltfox's Avatar
ltfox
Yup, that one will work. I would'nt worry about the higher boost. The rough compressor wheel edges may just lose ya a couple pounds. 30+ psi is just hard on our turbo period. I'm jelous!
Old Jan 17, 2007 | 07:36 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
just curious, its a drop in K&n?? I noticed the drop in dont seal to the top lid cause that top lid is not straight. My last K&N gave me a tube of grease to seal it, after installing the lid thier were places the grease was not touching, I ended up buying one sided tape foam(weatherstripping), applied it to the lid and now its sealed. The reason I'm asking this is because I kinda want to keep the stock look but want to rule out if its the filter element thats allowing the dust penitration or if its the seal.
Old Jan 17, 2007 | 10:07 PM
ForemanES's Avatar
ForemanES
Ya I had a drop in like 3-4 years ago. It came with the vasoline grease stuff to help it seal and I started to read on here about the bad seal in the factory box. Honestly I dont know if it was the seal or the filter itself, they have a lot less layers of media. I then got an AFE drop in filter it had a ridge of rubber where it sealed and bigger pleats. If you want it pm me I kept it for 8-10,000 miles then read of the 6637 and never went back.
ltfox I had 250,000 miles on my original injectors and the stage 1s made a day and night difference how it runs. Oh ya and now I understand what "stupid thick" smoke looks like <<<----- that was me during my 2 hour "test drive"
One other question.....
The superior wheel actually flows less air than the stock 00-03 7.3 turbos, but will it cause stalling issues with our turbo?
Old Jan 18, 2007 | 05:25 PM
ForemanES's Avatar
ForemanES
Do you have to remove the downpipe and hold the turbine wheel when doing this? It looks like there is a nut on the wheel itself to hold onto while taking the bolt off. Here are some instructions I found for the 99-03 7.3 (click here) .
Also are there any seals or o-rings I need to replace when I'm in there?
Old Jan 18, 2007 | 07:59 PM
ltfox's Avatar
ltfox
I diconnected the down pipe. Then wrapped electrical tape around the end of a screwdriver and stuck it in the exhaust turbine. Then the whole wheel will spin off. Its pretty tight and ya get a little nervous tell it breaks loose then it'll spin right off. Seal the compressor housing with rtv to prevent boost leaks.
Old Jan 18, 2007 | 10:07 PM
ForemanES's Avatar
ForemanES
Cool thanks for the info, I might be able to install it next week. I will try to remember to take some pics
