Spare tire carrier bolts:
Old Jan 20, 2007 | 09:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
Ahem, -Shhhhh don't tell anyone. I always run a metal stem and point it down so I can check the pressure easy. Probably just waiting for some sort of disaster to befall me because I have violated the Ford God's rules...
I wish I knew why they specified for it to point up. maybe it has something to do with the rim offset. My rims always seemed to fit fine tho... Dono on that one.
Old Jan 21, 2007 | 12:27 AM
Mil1ion's Avatar
Mil1ion
To keep it from getting all Mudded up.
Old Jan 21, 2007 | 08:46 AM
jimlj's Avatar
jimlj
Think about it for a bit guys. With the valve stem down, what do you have to spend ten minutes doing on the side of the road if you have to crawl under your truck and get that spare? Clean the mud and dirt out so you can mount the thing. Most of the guys still driving one of these trucks the comon sence to do this. For the rest of the idots out there Ford covers their back side so they can't be blamed when the wheel falls off.
(At least that is MHO)
Old Jan 21, 2007 | 10:35 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Ah ok, that diagram will go into my 1980 and up only data then.
Glad someone posted the right one then. I wish there were refference dates on each page of this stuff sometimes.
To be honest, I've been mounting the tire in the carrier backwards for years then. No ill effects yet. Knock on wood.
Old Jan 22, 2007 | 02:44 PM
BigShelby's Avatar
BigShelby
NumberDummy...
Can you tell us if N805270s56 will work in place of 384581-S nut and carrier (aka blind nut)? This is still avail. vs. 384581-s which Green doesn't carry. Thanks.
Old Jan 22, 2007 | 02:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BigShelby
NumberDummy...
An N preceding the number refers to metric.
384581-S replaced an earlier number...try: 383377-S2
Old Jan 22, 2007 | 04:46 PM
BigShelby's Avatar
BigShelby
NumberDummy..
I called Green Sales back with the other part #, no luck. After talking with the guy he asked what this was for. I told him and he referenced the original part # 384581-S. I told him I checked earlier today and was told they didn't carry the part. He said "WRONG!", "We got a bunch of those". So I ordered 4, just to have spares. Cost about $3 each.
If you need this part or think you'll need this part get 'em while they're hot because all these parts are difficult to get.
Thanks for all your help.
Old Jan 22, 2007 | 05:40 PM
leonharu's Avatar
leonharu
I just called Green Sale and they did not have it.I gave him #384581-S and #383377-S2 and he said no for both!BigShelby is that a metric or american j-nut?Do you know who you talked to at Greens?Thanks,Russell
Last edited by Torque1st; Jan 22, 2007 at 08:31 PM. Reason: rem- the @##$$%^^head said
Old Jan 22, 2007 | 08:33 PM
Torque1st's Avatar
Torque1st
Posting Legend
Just get a 1 x 3 x 1/8" piece of steel. Drill/punch a 5/8" hole thru the center and weld a 1/2" nut on it. It works better and longer than the flimsy spring clip.
Old Jan 23, 2007 | 06:59 AM
BigShelby's Avatar
BigShelby
Russell,
Ask for Tom. You might have talked to the same person I did the first time.
Old Jan 23, 2007 | 07:01 AM
BigShelby's Avatar
BigShelby
Torque,
Do you have to drop the gas tank to weld using your method?
Old Jan 23, 2007 | 12:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
Nope, I just made the part in the shop then dropped it on top of the lower flange after I had coated it with grease. Just run the bolt up thru it. The plate keeps the nut from turning. The spring clip does the same thing on the OEM part. They use a spring clip on the production line for assy reasons. The thin spring clip holds dirt and salt all around it and rusts thru rapidly letting the nut spin which is then a devil to get off. Murphy's Law says it will twist off when it will be most inconvenient. -That is at night, with 3" of snow on the ground on a muddy gravel road while it is sleeting...
Old Jan 23, 2007 | 01:13 PM
  #28
NumberDummy
Exclamation Blind Nut
NOTE: 384581-S has been updated to: 384581-S100
Yes, Green Sales has them...over 30 in stock..I just called them.
Old Jan 23, 2007 | 05:09 PM
  #29
1977Ranger250's Avatar
1977Ranger250
I am new on this site and do not know about Green Sales, What is the contact info for Green Sales ??? is there a web site or phone number ?
Thanks
Old Jan 23, 2007 | 05:34 PM
  #30
BigShelby's Avatar
BigShelby
Green Sales 800-543-4959 http://www.greensalescompany.com/Gre...sInventory.asp
jekyll_hyde
Bronco II
May 6, 2017 01:22 PM
71fordallen
38
Oct 6, 2016 01:33 PM
john jamieson
1983 - 2012 Ranger & B-Series
Sep 5, 2016 09:16 PM
waldreps
13
Jun 7, 2005 04:26 PM
greystreak92
1978 - 1996 Big Bronco
Dec 7, 2004 07:05 AM
